i like the sound of that idea bob, but how do you build the mobile base around the base of the p/t if its sitting on some blocks ?9fingers":14pdj4iq said:If you are using an axminster or similar mobile base then no need for the engine crane.
Walk the P/T off the pallet onto a couple of blocks of wood a couple of inches off the floor. You can then assemble the base around the P/T.
With the wheels in the UP position, slide some packing under the wheels, then move the wheels to the down position. This will lift the P?T off the blocks Withdraw the blocks and roll the machine off the packing pieces.
HTH
Bob
OPJ":p5og5sbv said:Workshop's looking really good Paul. Did you do all the electrics yourself? :shock:
Don't know if you plan to ever use the mitre fence on your bandsaw, but you'll probably have a lot more luck with it if you turn it around!
When you come to lifting the planer, don't forget that it's bolted to that ply and chipboard "pallet" - you can free it with a spanner by loosening the four (?) bolts from underneath.
Have you had a chance to play with the bandsaw yet?
