So i was going to get a lump of cast machined down, but just got a quote on getting some 8mm steel plate lasered, and its basically less than the cost of a decent cutter.
Im well aware of the flatness issues with steel vs cast, but, in my opinion, if an 8mm steel plate starts out flat, its probably going to remain flat enough for my work.
This is my plan for a triton tra001. Theres no big insert place cut out, as ill get the mounting holes lasered direct into the plate, and then countersink them.
The yellow is 50mm angle frame below, which ill bolt to the plate. Id weld it, but the heat may cause distortion, so ill use M8 countersunk.
Size is 700mm x 500mm. I dont want to give up more space. Its for template routing only.
I understand that a sheet of mdf would do the job too, but the 8mm laser cut steel below will probably cost me about £35, so its hardly worth driving to the shops to pick up a sheet of mdf.
One thing im not sure about is dust extraction - ill enclose the supporting frame and stick a dust port on, but, assuming i use a 75mm insert, theres not really going to be much space for the dust to get into the lower section.
I guess i could stick a load of holes around the outside of the plate, just inside the frame, but that seems a little unconventional?
This is just for template routing, nothing else.
