Question: Finding center of stock for the Lathe (tail end)
anaminal":27xyowgn said:
Chas - interesting points. I'd not considered the grain density producing differing compression at the chuck end or the grain folding at the tail-stock. Also I'd never heard of cone centres, so I could look into. Many thanks!
AndyT - planing after turning is something I had thought about, and I think should work very well where the turning has been slightly off-centre, thanks!
Nev - that is indeed the problem, cheers for the info on jig you tried.
Jacob - Marking Gauge method sounds good, I'll give that a try tonight.
The [current] project is making tool handles with a ferrule holding a blade in place. As the ferrule outer diameter is just 1mm less than the outer diameter of the wooden handle it buts up against, it is very obvious when it is off centre. (it's basically in line with the handle on one side and set back from the edge on the other).
As I see it there are so many sources of error (below) I'd like to make sure I'm not introducing any additional ones with the wrong method. Thanks all for your input, given me plenty to think about.
possible sources of error:
Rounding errors / inaccuracy in measurements
Difficulty of holding a ruler in place while drawing the line corner to corner :(
width of pencil line
Grain folding towards path of least resistance
Human error in holding the turning gouge!
P.S. to Rodders: I have not (and I'm sure this applies to many others) received any woodworking education other than Youtube videos, library books and the people on this forum; so when someone asks a question with an obvious answer it's not really helpful to open with sarcy post belittling em.
Chris
I am sorry that you feel insulted, This was not my intention.
On reading the Original Post, you asked how to centre an oblong, for turning, with no other information forth coming.
I wondered if this post was a wind-up, and said so, in reply, to you, which you ignored.
It has taken 18 posts to get to the full question on the difficulties that you are experiencing.
A fuller and more informative question would be helpful to a faster conclusion.
I see that you were not insulted by post 2 complete with a picture of drawing 2 lines with a pencil!
Regards Rodders
In fairness to Rodders, when I read your first post I thought you were having a laugh too. As the thread developed it became clear what the real problem was. But the first post sounded like you were asking an overly simple question and I think that's what solicited the responses you got. No one was being unkind.
