woodguy7
Nice review. I just fitted my workshop out with daylight tubes yesterday. Wow, cant belive the improvement
Woodguy
Woodguy
Geir":c4i0ukd9 said:A couple of questions, Byron:
I don't quite get your blade flattening and sharpening procedure. Could you explain that in more detail, please? I use the David Charlesworth triple bevel method myself, but it seems you skip a few steps?
That 3M product you use for flattening seems interesting. Do you have any idea of how coarse it is, compared with ordinary sandpaper?
What do you use under that paper when flattening. It looks like MDF, but surely it can't be?
jimi43":3sqtizke said:Assume that is an Eclipse jig you have there...judging by the bottom photo...? It may be my eyesight or the reflection but has it skewed the microbevel a tad?
bugbear":z24hks78 said:jimi43":z24hks78 said:Assume that is an Eclipse jig you have there...judging by the bottom photo...? It may be my eyesight or the reflection but has it skewed the microbevel a tad?
I like the Eclipse because it does the important thing (controls the bevel), while still allowing operator tweaking of other things.
BugBear
0jimi43":1eiif10m said:I am aware of the Eclipse and the benefit of the narrow roller and cambers bugbear...I have one too. :wink: It just looked skewed in the light because the other side did not reflect.....
I prefer to get the microbevel straight and then just whip of the extremes by hand. It works for me.
BB...the QS finish and quality certainly looks more controlled than the RIDER from the example you received from Axminster.
Jim
ByronBlack":ng5a9w8x said:Jim - the finish of the QS is exceptional. You wouldn't feel ripped off if it cost a lot more than it does.
ByronBlack":2o232onv said:Jim,
I would have gone for the QS block in a hearbeat if it were available. But I was also intrigued to see how the axminster performed. I may even get the QS block and do a side by side test.
I think you'll be very happy with the No.3 if it's as good as my No.4
Without getting into the issue of different honing guides, I agree that the honed bevel looks skewed, even though it's not. As Bugbear says, the Eclipse allows you to control the bevel, but it's very easy to gradually produce a cambered bevel which is skewed unintentionally, caused solely by the narrow roller and unequal finger pressure on each side of the blade.ByronBlack":326eolif said:It is an eclipse jig, I have no idea what number it is though, its the one with the a single wheel, which makes cambering very easy, the bevel looks wonky due to my crap photography and lighting skills, I actually ground a very slight camber onto the blade, but the camera just can't seem to pick up the details very well.
jimi43":25vqsoe9 said:Perhaps this little baby would be another winner....and only £15 more...
matthewwh":2mlkdmex said:jimi43":2mlkdmex said:Perhaps this little baby would be another winner....and only £15 more...
The next batch might be a tenner dearer I'm afraid, I've been tinkering at the whim of various specialists in the field and had some modifications included.
Given that exceptional review...perhaps the Rider is not so hot as is first thought:
Jim
Einari Rystykaemmen":17uridhw said:Given that exceptional review...perhaps the Rider is not so hot as is first thought:
Jim
Maybe little bit off topic, but...
This block plane looks almost identical with Juuma block plane, which can be found here http://www.fine-tools.com/einhand.htm.
I have ordered one and it arrived this morning. I can write a little review when I have tested it.
