SketchUp Guru
Ah, thanks WiZeR. "Big Sheet ofPlastic" I understand.
StevieB":19u775on said:If you are going to put joist ends directly onto a concrete or brick plinth/wall I would advise seperating the joist from the wall with a strip of normal black DPM as used when building a house wall. This will stop water/damp penetration up from the brick into the timber. If the joist is not supported along its length you only need one end to rot slightly before the floor tips :wink:
Steve.
Dave R":3nzeu5oq said:OK Byron, I understand most of the dimensions you gave and I have something to work with. I need a bit of clarification on a couple of points.
6x2 and 4x2 lumber: What are the actual dimensions? Here in the US a 2x4 is smaller than 2"x4" and they seem to get smaller every year.
Dave R":3nzeu5oq said:DPM? What's that?
Dave R":3nzeu5oq said:6mx3m: Is that the size of the concrete slab? Or is that the exterior dimension of the shed? What's the 1m part that won't be used for the shed?
Dave R":3nzeu5oq said:re: Marine ply on the exterior side of the walls. You shouldn't need to do that if you are using T&G wood siding. I put OSB sheathing on my shed because I used vinyl siding. The siding is too flimsy not to be backed up. I think you should just build a boat with that marine ply. (This comes from a guy who wants but can't get marine ply locally.)
Dave R":3nzeu5oq said:Is this shed going to be built immmediately next to another structure or will you have some space around it?
Dave R":3nzeu5oq said:What sort of roof strikes your fancy? Single slope? Peak in the middle? Peak off center? One side higher than the other with a short wall of windows or vents? A gambrel roof?
Dave R":3nzeu5oq said:Doors: Are you going to buy commercial doors or build them? I built mine but wish I'd thought about buying a door.
Dave R":3nzeu5oq said:Windows? Any or none?
Sawdust":15reqtu4 said:Byron,
I'd be careful about putting your floor joists, tannalised or not, directly onto a concrete base because however you do it, water will gather and it will rot, it might take a few years but when it does, your shed is knackered and they are almost impossible to replace.
Final bit of advice; work out how big you need it to be and then multiply by at least 2. When I built mine I thought it was massive but in truth it was tiny!
Hope this helps
Mike
Dave R":bgzkwrbo said:I have another question for you. Would you want to use some of the space in the rafters for storage?
