chippy1970":f8d59p68 said:just sold mine for £100 had it for a couple of years had it replaced by trend when nearly out of warranty so it was nearly new. I never used it because I thought it was a rubbish router.
Mine was a 110v one with all the kit.
That's what I was planning on using it for - with the CDJ600 dovetail jig.mailee":2ou0b4t5 said:It just so happens that I now use my T5 for cutting dovetails
Rich":h27yr0jw said:As you are all well aware, I am only a hobbyist woodworker, but having purchased 3 routers from Aldi for £20.00 each, i am well pleased if I get a years use from them, I have had them for 3 years now and they show no signs of failing, I suppose the same could be said of buying a rolls royce or a skoda, both vehicles get you to your destination, but if the roller breaks down it will cost a lot more to get it roadworthy than a skoda, some would say that if you can afford to buy a roller you don't need to worry about such things, but in reality, you can pick up a second hand roller for a couple of grand, it's the running costs that hurt, I am sure that trend could produce a more marketable router, but they choose to keep their brand "high end" as do rolls royce, consequently, the normal run of the mill diy'er like me, turns to Aldi, I know who the winner is. :wink:
Regards,
Rich.
p111dom":1skzys0q said:I've had my T5 for about 5 years now and I have had none of the problems above. Perhaps production quality decreased after mine was made. It is a little under powered and is not suitable as your only router but for a hand held router it's great. Perhaps it's the way I use it. I don't or rarely use it as a plunge router per say. I always have the fine height adjuster on so have never had any issues with the smoothness of plunge. The T11, Dewalt 625 and the CMT version are all made in the same factory and I would be suprised if that wasn't the case with the identical looking Dewalt. Obviously Dewalt/Blackand Decker took Elu over some time ago so any Elu router you fine will be getting on a bit now. Other than that I can't see why the Dewalt 615 differs in any way other than colour. The best thing with the Trend is that they specialise in routing so the list of extras available is extensive and readily available. All of these should fit the Dewalt as well in theory but it's a guarenteed certainty with the Trend. I use mine for rounding over edges, laminate trimming etc. All of these thing a fixed based router would be better for but they weren't available when I was looking for a small router. Now that they are, while I would consider them, they cost significantly more. Yes there are better routers in it's class on the market but not for the sub £100 you would pay for a good second hand one. Strangely I aslo have a old Elu MOF96 which is 110v and the base of that is bonded on as well. I guess it depends when they were all made.
