Tony - thanks for the offer. I don't intend to make these drawers for a couple of months yet, but if the offer is still available by then, I may you take you up on that, thanks!
Scrit, Dom, Charley, Jason etc.. thanks for all the advice, I guess with the number of drawers I have to do; 20+ i'll need to start thinking in terms of workflow and batch processing to make it a painless task.
Jason, when you say 'this is how I make them' - do you mean with pocket screws, or the lock-drawer joint?
Scrit, these will probably be made out of 15mm or 18mm ply, with 6mm bottoms. Due to the material and it's want for splintering, i'm not sure a rebate plane would be an option for this?? Not tried to plough/rebate into ply before.
If I were to try and do the lock drawer joint with a single straight router bit, is there a certain procedure I would have to follow - I can't visualise it in my mind at the moment, probably because i'm clouded with the one-cut operation of the specific lock-drawer cutter.
Thanks everyone, some good info there!
Just thought of another decision I need to make, incorporate separate fronts, or not? Any impact on the methods recommended so far?
