Blister,
Do you have the Sundstrom 570SR with the Sundstrom 500 respirator?
D.
D.
YesBlister,
D.
Yes but have you seen the price of a new set of lungs! Let alone the price of anti rejection medication if you even qualify!,,,,,,!,,,,!I started work back in 79 at Thames Marine who built GRP yachts & industrial mouldings. The guys who trimmed the mouldings were issued with the then new Racal Airstream helmet powered respirator, I believe they were designed for the mining & other hazardous industries. One of them showed me this bit of kit & told me what a difference it made.
In 84 I set up on my own & bought an Airstream powered respirator. At that time it cost £200, I worked in most of the local boatyards & i think i was the only bloke who owned one. At times doing a lot of GRP repairs & wood machining & sanding I virtually lived in it.
It lasted 20 years then i bought another one. 15 years later that one was getting worn out, Racal was brought out by 3M who continued making them, i bought three of them secondhand stripped & cleaned them & bought a pile of parts to keep them going. Most of the parts are still available except for motors which i cant find.
One of those GRP trimmers (who refused to wear one) died of silicosis, Several other chippies i know died of Copd & several more are now having problems.
You cant buy new lungs so investing in a good respirator makes sense!
3M, Sundstrom & Martindale are three manufacturers that spring to mind.
A quick google finds the following, Air Fed Mask | Powered Air Respirators | Air Fed Respirator Mask ,
Make sure you are sitting down when you look at the prices!
The trend respirator offers no protection to the head and has no rating. The power cap has a bump cap rating. I don't claim to be an expert on that but it's a different standard to hard hats and sounds like it's a lesser rating.The power cap and Trend face shields will offer good protection from impact to the face and head when regular woodturning.
What face shield do you use that has a high speed rating and which rating does it have?There was a sad news story posted on here a few weeks back of a 30yr old who recently was hit and killed by a workpiece flying off his lathe.
I hadn't fully realised that different safety glasses/shields offer different impact protection and shouldn't be used with some high speed tools. My full face shield is rated for high speed impacts as are my bolle glasses but my standard type dewalt glasses are not.
I'm not using anything fancy just the cheap one from toolstation but it is B rated which is rated for 120m/s impacts, but even the more expensive ones seem to be B rated so I figure it should be ok. More expensive ones will most likely have perhaps a better optical rating or have a better shape etc. A lot of my safety specs are only F rated which is 45m/s.What face shield do you use that has a high speed rating and which rating does it have?
I note that you are in Canada, so lung transplant and associated medication would cost a fortune. Here in the UK we have the NHS....Yes but have you seen the price of a new set of lungs! Let alone the price of anti rejection medication if you even qualify!,,,,,,!,,,,!
If you qualify, transplants are paid for here too if you live long enough to get one, although some medications would be on your dime. Each province is a little different as each runs their own show.I note that you are in Canada, so lung transplant and associated medication would cost a fortune. Here in the UK we have the NHS....protection!!!
In Canada our medical is free! We do not even pay a monthly fee.I note that you are in Canada, so lung transplant and associated medication would cost a fortune. Here in the UK we have the NHS....
Not that is any recommendation to not use dust protection!!!
You don't pay a dime in bc. Employers pay everything. Changed years ago. And I just ordered a. 3m system.Depends in which province you live in Lefley. When I lived in BC I paid a monthly fee (about a hundred a month) until our union negotiated for the company to pay it. If you were poor then the province covered it. When we moved here I found out there was no fee. So each province is different.
Now let’s get back to talking about powered respirators.
Not compaired to a new pair of lungs " If you can find any "It seems to me that powered respirators are as ridiculously expensive as everything else associated with wood turning.
D.
You are absolutely right that this kit is £££.I'm struggling to believe the prices of these things, seems like a total rip off to me. Just look at the prices of some of the spares. The Powercap for instance, 4400mah battery - £108 I bought a 10,000 mah battery a couple of years ago, gets used all the time £16
And then look at the price of some of the more upmarket ones with belt mounted filtration units - £1000 - just stupid made up prices.
I might just make my own, can soon knock to gether a belt mounted air filter unit, connect via a flexible pipe to some sort of face shield/ helmet, even a motor bike helmet!
Just looking at the powercap (the only one I could afoard) . It claims 8 hour run time for a 4.4ah battery Im thinking this is suggesting a fan around 2.75w
that is just a computer case fan!
I could soon mount two of them together and double the air flow of the powercap still only running at 5.5w (that is just over 1 amp) bog standard powerbank can easily do 2 amps.
Make a case and fit a couple of p3 filters - thats half the job done.
Any idea what type of fan is needed ? a name, a type. I am seriously interest in building one of these things, I have a 3d printer etc that should come in handy.The comparison with computer fans isn't fair though. Those really are a commodity item built in huge numbers, but they are also designed to move highish volumes of air against very little resistance. Put one or even two against the resistance of a P3 filter, part clogged, possibly a corrugated flex hose etc and I expect that it won't do well at all. You need a differently shaped turbine that creates higher pressure. Probably a squirrel cage - like you find in some laptop fans perhaps but substantially bigger. They are not rocket science but someone has to design them, invest seriously in injection moulding tooling and manufacture in much lower volumes than computer fans.
Hi BlisterNot compaired to a new pair of lungs " If you can find any "
Sundstrom's SR500 has a two speed fan that delivers 175 or 245 litres per minute.Any idea what type of fan is needed ? a name, a type. I am seriously interest in building one of these things, I have a 3d printer etc that should come in handy.
I'm going to mock one up in the next few days with some 12v computer fans, P3 filtes , see if I can get some measurements of air flow rates. I will need to get some measurements from proper ones so that I have a goal to aim for, not sure how I will achieve that though.
