flintandsteel
I recently bought a second hand PowerCap ip as an affordable intro into using a much needed respirator.
I was diagnosed with COPD (damaged lungs) and while I've used those tight fitting muzzle type masks with filters they have limitations, particularly as regards long term comfort or wearing glasses.
The battery on the PC ip is the 8hr type but I find that JSP no longer do this particular battery pack.
I read somewhere on this site (can't find it now) about renewing battery cells.
The battery works ok, but maybe only about 4 hours instead of 8, it's a bit tired. Also if on charge (not quick) then I'm without a respirator in the meantime.
Does anyone have advice on replacing the battery cells or rigging a compatible power supply?
