When I took over running the Chinese factory that was making earth leakage current detectors and other electrical test equipment the first thing I did was have a random sample of the products tested against primary standards. Everything failed. So donning my best Deer Stalker and pipe with fiddle under arm I began the investigation. Everything seemed fine until we got to the building earth. They knew that the earth was important so had one installed……it was a wire that was imbedded into the wall 6” or 150mm. They proudly told me the building had first class foundations and therefore had a good earth.
A certain ‘high’ value well known brand who makes yellow coloured test equipment when I tested their clamp meters around 20 years ago were only accurate when the conducting wire under test was exactly perpendicular to the clamp, and exactly in the centre. Any other position and it failed its calibration.
The morale being unless you know exactly the quality of the test equipment you are using, and what tests to perform, and exactly what your doing, your basically juggling with a powered up chainsaws, you might get away with it a few times, but eventually it’s going to kill you.
