Hey Stig don't know if you see the Lidl weekly but the young lady is going to have a bump holding the tool like that , Bad example being shown there
I know how you feel fell off a ladder on Saturday only a small fall bruise and scrape to forearm rip to old jacket - dodged a bullet!@Jameshow I can't believe how lucky I am, barely a scratch on me and no real bruising, my nose is a little sore and I've had a slight headache since but we went to the hospital on Sunday and got a scan to be safe and they say there's no visible damage so take ibuprofen and go easy for a few days.
@Thingybob I've seen that one, I'll have to have a search![]()
I hate ladders, don't mind heights but ladders are dangerous.I know how you feel fell off a ladder on Saturday only a small fall bruise and scrape to forearm rip to old jacket - dodged a bullet!
Glad it was me and not a volunteer.
So today I got back into the maker space after Fridays entertainment and decided to start on a project I set myself, our godson and his partner are getting married so I thought I would make a pair of the Victorian figures I made for the school fair but bigger, today I got the female form done, I'm happy enough with her, my only negative is the head, I think it should have been taller and taper down to the neck as it looks squat and round.
Made from Ash with a little bit of spalting, stands about 9 inches tall and finished with linseed oil, will add a couple more coats over the week.
View attachment 150873View attachment 150874View attachment 150875View attachment 150876View attachment 150877
Sore to touch but apart from that I'm good thanksBack on the horse after the fall as the saying goes. Looking good and hope your not to sore
Looks great! I still have mine I got as a kid as well as my brothers traction engine.View attachment 151167
This Mamod Roller was mine for a few pounds.
It did need a whole lot of work.
Nothing moved.
The level plug is missing, filler plug is serized and the boiler boss is spinning. Plus the whistle is broken.
This is the bottom of the chimney, you can see the lime scale. The boiler was worse.
Hot citric acid had it removed.
This was not good.
The rebuild.
Home plating kit had the fire box shinny.
Fire box was d erusted and the holes mig welded up.
Right hand side is the repaired roller. TIG welded into place.
Not the best welds. As TIg welding cast alloy is not easy.
Why did I not buy new parts?
Why when I can repair most parts and keep it original.
Rebuilding the engine.
New boiler Boss fittings were soldered into place. New/old stock whistle was brought. Safter valve rebuilt with new seals/
New sealed rivets are also used..
New Stock sticker, new burner tray and a home made scuttle.
Finished.
That is a beautiful bowl! Getting the inside tidy must have been quite a challenge!After work this evening I chilled out in my workshop and turned a little bowl. Nothing special , and I guess it’ll hang around the house and get used for sweets or spare change etc. But I really like this shape for some reason.
Lovely. I had card scrapers for Xmas and using an old screwdriver on them just doesn’t feel right.A burnisher for my scrapers. Made using a 6mm tungsten rod. Handle is from a type of Laurel cut from the garden, a few years back. The ferrule is stainless steel, as I have had brass ones crack in the cold of my workshop.View attachment 151295
