Your talent blows me away, these boxes of yours look like they belong in an 3xpensive galleryMaple Burl stabilized with blue! African blackwood Top and bottom.View attachment 125317
Thanks. A lily pad box I made for wife’s sister at Christmas. Stabilized maple Burl.Your talent blows me away, these boxes of yours look like they belong in an 3xpensive gallery![]()
This is very impressive. I presume that you turned the balls with stems, to attach them to the box but how did you hold the little dish at the top while you turned it? I presume that the stem of the ball passes through it, did you hold the dish in a jam chuck as you finished it?A lily pad box I made for wife’s sister at Christmas. Stabilized maple Burl
Driftwood and rubbish bits of wood sculpture
Don’t ever think you can’t turn something. Now embellishing something that’s a different story. That’s where I have trouble. But turning is methodical. Approach it step by step.This is very impressive. I presume that you turned the balls with stems, to attach them to the box but how did you hold the little dish at the top while you turned it? I presume that the stem of the ball passes through it, did you hold the dish in a jam chuck as you finished it?
Your fine turning is completely out of my league.
Martin
You make it sound so simpleDon’t ever think you can’t turn something. Now embellishing something that’s a different story. That’s where I have trouble. But turning is methodical. Approach it step by step.
the box above has a waste block glued both ends then when held between centres I turn the box and waste blocks round and put tenons on each block to hold then I recheck one end to hold and part the lid off the box.
sorry little blurry but you get the idea.then when parted I can hold each piece separately in chuck and turn. I do inside first an$ I sometimes leav some decorative groves inside box, with one groove being a way I can expand a chuck into it to hold it to turn the outside top and bottom.
View attachment 125333View attachment 125334View attachment 125335
this is the side of a lid, you can see groove I can expand chuck into.View attachment 125337
lastly legs and finial. The balls I drill and dowel. The finial sometimes I leave some wood to glue into a drilled hole. View attachment 125339
I’ll also add some groves in the stub I leave on bottom of finial for the glue to grab hold of better.
You make it sound so simpleyour skills are 100% something to aspire to, I look forward to the day my skills can produce something so exquisite
Witchcraft! There is no way that should work!I made this. It was in an Intructable email, and my best beloved looked at it and said "You could make that this afternoon." I assumed I was going to prove her wrong and just make misery and sawdust, but lo and behold I made it and it works. Though when you see it this close up it's clear that I'm not great at lathe stuff, or finishing stuff. But I did finally use the O'Donnell jaws I bought a very long time ago, and the Axminster press brake I've had for a decade and used (now) five times, so I'm actually quite pleased.
It is an Epicyclic Bar Angular Transmission or Hobson’s Joint or, if you prefer, a fiddle toy. The two barrel bits (made from an offcut of an old guitar body blank) rotate at 90° to each other. The rods are made from a welding rod that I chopped with bolt cutters, rounded the ends on a sanding drum, and bent in the press brake. Took about 2 hours total, including trying to remember how to work my lathe, and the fixing of several mistakes. The Instructable, which includes 3D printing and laser cutting approaches, is here - Twisty Toy
OK, I challenge you to make some Penrose stairs.That's what I like about it!
I have a book of odd mechanisms. I might try making some of those.
Verrry nifty!!!I made this. It was in an Intructable email, and my best beloved looked at it and said "You could make that this afternoon." I assumed I was going to prove her wrong and just make misery and sawdust, but lo and behold I made it and it works. Though when you see it this close up it's clear that I'm not great at lathe stuff, or finishing stuff. But I did finally use the O'Donnell jaws I bought a very long time ago, and the Axminster press brake I've had for a decade and used (now) five times, so I'm actually quite pleased.
