Lovely looking table.This was a change from the small scale ornament curiosities that I've been making over the last year.
We recently created a dining room and moved in the accompanying dining table from the kitchen where it had always been a tight squeeze, especially when extended to seat eight. This meant, of course, that we had no table in the kitchen and it is somewhere we like to sit and look out on the garden. Mostly, there are just the two of us at home these days so a table that was comfortable for two and extendable to four would suit well.
I eventually decided on an oval drop leaf table (in maple as I still have a fair bit left over from a kitchen project many years ago) and using rule joints for the drop down leaves. The rule joint took a few practice attempts in some scrap 18mm mdf to get them right, well to get it working at least. And even then I miscalculated the width of the centre panel as I forgot to allow for the leaves dropping back under the centre panel by 12mm on each side. This meant I had to cut the panel in half and insert another narrow strip to widen it which you may be able to make out by the grain variations.
The supports for the leaves are bars that pull out from the table frame and are held in place by the table top. Stop blocks on the other end of each bar to the small knob limit the distance the bars can be pulled out.
I'll be honest, I prefer the small ornamental work but I'm happy with the result!
made this butlers tray and stand out of a beam removed from the building in the background which I rebuild a few years back, it's a coach house built in the early 1840's, now my workshop.
Made the tray because I panelled a room in reclaimed pine and got told the table don't match it Mahogany, just need the butler nowView attachment 117051View attachment 117052View attachment 117053View attachment 117054
sorry, will get a pic of it and post it tomorrowKrissKross
tried to open the attachment but no go....
Repaired the stiles (is that the correct term?) on my front door, facings and frame rotten as heck. Chopped the frame out and replaced with a couple of chunks of oak. Facings are larch. Stainless screws and plugged to try and avoid the corrosion the old one suffered. A whole days work and a coat of undercoat as it was getting dark.
wow, these look fab and fun to makeWell, my latest and it seems that my balls are multiplying?
Left is mine beech and cedar. Right is a commission, black walnut and beech and the ball is because I like turning balls. Not sure what wood that is?
Nice one, I made one about a year ago and it makes me smile each time I use it. It’s a great little project.First effort at a mallet… I now possess a mallet which is good as I have hitting things stuff to donot finished yet but getting there
