This was a change from the small scale ornament curiosities that I've been making over the last year.
We recently created a dining room and moved in the accompanying dining table from the kitchen where it had always been a tight squeeze, especially when extended to seat eight. This meant, of course, that we had no table in the kitchen and it is somewhere we like to sit and look out on the garden. Mostly, there are just the two of us at home these days so a table that was comfortable for two and extendable to four would suit well.
I eventually decided on an oval drop leaf table (in maple as I still have a fair bit left over from a kitchen project many years ago) and using rule joints for the drop down leaves. The rule joint took a few practice attempts in some scrap 18mm mdf to get them right, well to get it working at least. And even then I miscalculated the width of the centre panel as I forgot to allow for the leaves dropping back under the centre panel by 12mm on each side
. This meant I had to cut the panel in half and insert another narrow strip to widen it which you may be able to make out by the grain variations.
The supports for the leaves are bars that pull out from the table frame and are held in place by the table top. Stop blocks on the other end of each bar to the small knob limit the distance the bars can be pulled out.
I'll be honest, I prefer the small ornamental work but I'm happy with the result!
