Alpha-Dave
I bought this while on a TIG / MIG course earlier in the year, and have since built a 8 mm thick holey-table, so this is redundant. Some scratches in the zinc coating on one corner (shown in the last picture), otherwise no defects.
£60 collected from Durham
The portable welding table is heavy duty, height adjustable and tilts so the user can select the best working arrangement for the task required. The Welding Table has 3 tilting positions 0* and 30* degrees for working and 90* degrees for storage. In order to help prevent rust, the steel work top has been coated in zinc.
- Folds for easy storage
- 3 tilting positions 0* and 30* degrees for working and 90* degrees for storage
- Fitted with 2 wheels for portability
- Adjustable Height (mm): 780* - 930*
- Table top material: Steel
- Table top dimensions (mm): 760* x 510*
- 3 slots to allow for clamping
- Item Weight (KG): 18*
- Ideal for TIG and MIG welders
