I'm working off an around 20 year memory which may well be totally inaccurate !
I wanted then to put a finish on the new window cill shelf and have this memory that I did a wipe finish using a poly varnish + shellac (sanding sealer) finish. It has remained as good as the day I did it.
Now Her-in-Doors has got me to make a coupe of corner shelves for the same area to take plants (in pots!), so I would like to see if I can use the same finish.
Is my memory a likely possibility, or something that is just a figment ? :roll:
Rob
Rob
