Pointless object
I was just thinking about @Inspector /Pete's advice and how to follow it. The quickest and easiest thing to do would be to add a sled to my existing jig to ride in the mitre rail. Of course I'd have to get the rail square to the jig .... or would I? I have a 2.8mm kerf to my blade, if I really want a say 5mm slot would it be an absolute no-no to deliberately fit the sled slightly skew so that the workpiece goes over the blade off square, and so enlarging the effective kerf? We're talking I think about 0.5 degrees here, or thereabouts. I was also thinking that this might cut a flatter base to the slot without having to change my blade to one with flat cutters ...
Or perhaps this is playing with fire, inviting the table saw to take my jig and throw it at the wall .... or at me ....?
What you are basically describing would be cove cutting but instead of nibbling away a little at a time you would be trying to take it all in one go. That would bind as the teeth would be side cutting and because of the amount of wood you would be trying to take wouldn't be able to keep up. Note too as you cut wider the slot won't have flat sides or bottom. Coving with the saw can be useful for small jobs where you need the shape cut and you don't want to invest in other tools to do it. It isn't normally done with sleds and the like.
looks very good, Nice work.
Are you aware it's upside down? .......... 😜
@Jacob those are definitely work of art chairs. Reminded me of my mother: she always thought we bought our chairs for looks rather than comfort (this is years ago now, nowadays comfort is essential!). In her words 'Torquemada chairs", Torquemada of course being the guy who ran the Spanish Inquisition back in the day when it was a byword for torture.
I'm trying to figure out if I can reverse these jig fixtures easily so I can run a tracksaw over the top since I don't have a tablesaw. Seems possible, just slightly more complex.
Believe it or not they are actually quite comfortable. The geometry is right, but you wouldn't want to trip over one with all those sharp corners.
That's odd, when nobody expected the Spanish Inquisition the preferred method of torture was the comfy chair.
So I did another, this time in walnut, for the friend whose idea it was.
As I mentioned in passing earlier I wanted to get fully bonded joints, the dovetail splines I used first time round were quite shallow and I found it hard to get decent clamping pressure on the mitre particulalrly on the inside of the corner (I've been using Titebond II for this project so clamping pressure is critical for a strong joint).
So I adapted my mitre spline jig to use it on the table saw as @Inspector /Pete suggested and had no problem at all cutting fairly deep (~30mm) slots for plain splines (not dovetailed) and planing down some scraps to use as splines (planed down to interference fit).
To get good clamping I thought it would be a good idea to use a drawbore technique, so I cut a couple of 4mm holes either side of the mitre, and made corresponding holes in the splines, but these holes were a few millimetres closer together; putting a couple of 2/3mm oval nails partly or fully through closed up the gap between the mitres and indeed put the mitred faces into compression, spline in tension. I glued up six subassemblies this way and was pleased to see that the mitres were now absolutely in contact, and the joints seemed strong. I took out the nailes when the glue was dry, enlarged the holes to 6mm to get rid of any bruised wood where the nails had been pressing, popped in some dowels, and altogether felt things were going pretty well.
Having made the six subassemblies I was now ready to glue up the joints between the subassemblies; I left overnight for the glue to set, and after taking the nails out ther next day and inserting dowels instead I was ready to start sanding .... and that's when I dropped the workpiece accidentally on the floor. Since I have 19mm rubber flooring in the workshop and the workpiece weighs next to nothing I thought I would be ok, but I knew I wasn't when I heard a big cracking sound. It turned out no fewer than four joints had broken: the splines had snapped and the joints separated.
I realised what had happened: there was way too much tension in the splines, and the tension was still there wIth glue set; and once one spline snapped the resultat shockwave snapped more in a sort of chain reaction. I had once again snatched defeat from the jaws of victory!
I repaired the broken joints with epoxy, wishing I had used epoxy throughout (since thickened epoxy bonds well with light clamping.
I mention all this because the whole episode was typical of how woodworking goes for me, generally with me ending up having been too clever by half ...
Reading the forum I see that other members introduce themselves on joining and I feel embarrassed at my manners in not doing so. I'm 58, live in North Norfolk and started woodwork 2.5y ago when I retired. Having started off with hand tools only (other than electric drill), I bought machinery in 2019 (Wadkin AGS10 table saw, Startrite SD310 planer thicknesser, Meddings bench drill, Charnwood bandsaw B250 and Bosch GCM12GDL mitre saw). My main interests are making furniture for the house, and shipwrighting work for my boat (I have an Essex smack, built 1892) ....
