I’m sorry Pabs but I’m having trouble trying to see what’s happening in the pic, but will say ply normally breaks before de laminating unless the glue has failed due to water etc.
The rippling you see on that black top surface look like the undulations that sometimes occur during the final sanding to thickness that happens during the board's manufacture. The undulations occur because, for example, every now and then stray debris gets between the belt and the underside of the board as it's conveyed along the production line causing the board to bobble up and down a bit as it passes under the sander. And thinner ply is not as strong as thicker stuff making it more likely to flex a smidge as it passes through the production line.As in when using over enthusiastic clamping pressure? Is this what has caused this mostly optical undulation in this 6mm ply?
Ta!
