I can echo MikeJhn's comments about the Triton router in a router table based on experience and not tribal knowledge. The TRA001 is a great router if used as a plunge router, but not so good when used in an enclosed router table. If the router table was open, my knees were younger, and I had an extra elbow in my arms, I wouldn't have any problems using the TRA001 in a table.
I started down the path of the Triton router table, first with the Triton Workcentre and then to a dedicated router table with an Incra router plate. I never finished building my table with the Triton because I used a friend's over one weekend that was similar to what I was building. That experience was enough to convince me to abandon the TRA001 router table and go down a completely different path, with which I am very happy.
The TRA001 was mounted to a fixed Incra plate, with the adjustment access hole, and the only modification was to remove the plunge return spring. An Incra CleanSweep housing enclosed the router for dust extraction and the rest of the table was enclosed with side panels and doors. Anytime I needed to access the router, which was often, I had to open the main door, open the CleanSweep access panel, reach into the abyss and find the power switch or height locking lever.
