Flynnwood
Good evening,
I am changing a shower mixer bar and need to reposition the Offset Connectors to accommodate the new mixer. As per the photo, the original outlets were fitted slightly unlevel to accommodate the original fitting (not by me) and I can't attach the new one. It's about 2 to 3mm out on the horizontal and vertical plane across the 150mm span - hence the need to reposition one or both of the Offset Connectors. I can't even cross thread it if I try really hard.
Given I can't access behind the tiles, is this doable? (Loosen/reposition/tighten the offset connectors). Any tips?
