Nice old j marples war department 5/8 pig sticker bought for £4 plus p&p
Re fixed Loose handle with epoxy sharpened up and ready to try
It's simply a very robust mortice chisel. Used for mortices obviously, generally banging out larger mortices in harder wood in short order. No, you don't need one, but if you're doing a lot of that kind of work it is a time saver.I've never even heard of a Pig Sticker. Looks very cool, what do you use it for?
is that a striking knife on the right?
On the left a centre punch?
Actually for smaller mortices and soft or hard wood. You don't get the trad "oval bolster" mortice chisel above 3/4" wide (though I've never seen one) but they do go down to 1/8". They are designed for a very specific fast morticing technique which just gets too difficult as you go above 1/2" the most common size, as were used in millions of doors and window frames when hand tool using was the thing.It's simply a very robust mortice chisel. Used for mortices obviously, generally banging out larger mortices in harder wood in short order. .....
It was on your posts I decided to buy and try one @Jacob thanks will keep looking for another couple of sizes
Is yours actually 5/8" wide it looks less in the photo? They are intended to cut a precise mortice exactly the width of the chisel. If you then get set up to make your tenons all the same size and an easy push fit it saves a lot of fiddling about.It was on your posts I decided to buy and try one @Jacob thanks will keep looking for another couple of sizes
Rounded bevel is just a byproduct of normal fast freehand sharpening on an oil stone but it's actually useful on mortice chisel for cleaning out the corners of blind mortices.Thanks for the details @Jacob . I was interested about the rounded bevel which the pigs I inherited from my grandfather (master carpenter) all have.
I guess he was saying keep the chisel vertical, as that is the normal practice, but not obvious if you don't know how to do it. But he might have had ideas of his own!I seem to remember him saying that when you get the mortice going the bevel is vertical for quicker clearance. Any thoughts on that?
Thanks for the details @Jacob . I was interested about the rounded bevel which the pigs I inherited from my grandfather (master carpenter) all have. I seem to remember him saying that when you get the mortice going the bevel is vertical for quicker clearance. Any thoughts on that?
