Please help ID a mini bench drill
KingAether
Eternal noob
14 Jan 2020
Dorset.
Evening all,
I was very kindly given a tiny bench drill today and i would like to ID it so i can see how it would look restored; i've spent many hours looking through a bunch of the likely culprits with no luck but its very clearly not home made, thought the base is likely a replacement/repair as the welding job is pretty bad and far from the quality of the rest of it being cast.
-It has a small 32/33 stamped next to the lever that clamps the pillar and a square raised area above the spindle handle but no rivits so unsure if its a data plate under all the paint or just the casting.
-It has a 6mm EVA chuck
-The depth stop is the trigger looking part between the handle and the body- it turns ahead of the handle and a bolt behind can be raised and lowered to stop it where you want.
-I assume there was a ruler of some kind in the slot front left by the tension spring cover.
-The top lid is a flat casting with 4 pins that fit perfectly into matching holes in the body
-2 speed and look original, i dont think it could fit a third wheel in there
I was given the original switch and i was told it works but the toggle has broken, does anyone know where i can get a toggle or whole new switch like this one pictured, its a lovely little thing and takes some good pressure to flip. It fits the holes on the left of the body
I'd very much like to get it looking like it should and the first step is finding out what it is so any help or ideas are appreciated!
Thank you
181411903_210831457216118_3266494756627252444_n.jpg180807932_503796754105793_2856478972084359943_n.jpg179718443_556619758835031_207598409960708371_n.jpg178830803_1124661348049740_1138945918465671897_n.jpg
I have taken a look thought lathes.co.uk and can't find it but im sure there are more there i missed; hopefully someone can come along and help ID it
