TheTiddles
I thought they were a decent company?
Yep I agree HPH is not suitable.
Rutlands are just above scam merchants, but only just
I’ve just been using my Kreg jig today , the amount of play in the jig is zero, there is enough clearance for the drill bit to rotate but nothing more.thanks but this wes a test really and and I purchased for birch ply not the HPL. That said there is still a lot of play in the drill bit. Just wondered if anyone had a Kreg to see if theirs was the same. I cant recall the trend ones having as much play.
Thanks,
Thanks. I'm off to local shop to check out the Kreg. Only thing put me off kreg to begin with was the imperial markings. I know you can get a metric block but surely thy should have a metric kit available. CheersI’ve just been using my Kreg jig today , the amount of play in the jig is zero, there is enough clearance for the drill bit to rotate but nothing more.
With the Kreg bit in the guide it would be impossible to insert a 1mm wide piece of typing paper.
your jig is faulty and should be returned
There are a couple of videos on the Hooked on Wood channel on youtube talking about this problem :
I don’t have the K5 jig, it wasn’t released when I got my K4, over the years I’ve used every bit of the supplied parts apart from the distance stop, I have got the small block and drill bit for narrow stock that works as well as the big bit.Thanks. I'm off to local shop to check out the Kreg. Only thing put me off kreg to begin with was the imperial markings. I know you can get a metric block but surely thy should have a metric kit available. Cheers
Is it only the k5 jig available in metric or new k4? CheersI don’t have the K5 jig, it wasn’t released when I got my K4, over the years I’ve used every bit of the supplied parts apart from the distance stop, I have got the small block and drill bit for narrow stock that works as well as the big bit.
A labler works well to adapt from imperial markings.View attachment 104669
Has anyone thoughts on the Trend and UJK models?
You absolutely need the clamp lever to be the same side as you drill, so the neither the UJK or trend is good.Has anyone thoughts on the Trend and UJK models?
