keithy1959
This only applies to front-to-back fences though, doesn't it ? If the fence stops at the blade then most movement caused by an out of square fence will be able to move away from the back of blade - or have I got this wrong ?I don’t think you understand how a fence works. It won’t simply cut a taper it will cause the saw to cut on opposite edges of the kerf. If the taper is toe in, closer at the back of the blade, that is asking for nasty kick back. It will produce a straight cut with a wide kerf set like this but almost guarantee kick back at some point. If it is toe out you might be able to hold it against less aggressive kick back but the work will inevitably wander away from the fence as the kerf tries to follow the blade, not the fence, and you will finish up with terrible cuts and hopeless accuracy.
Richard
