Bojam
I have finally decided on this machine, because it has helical cutters and I need to take noise into consideration. It is a little bit over my budget, but I will save up to it.
https://www.bernardo.at/en/ad-260-s-230-v.html
I would like to ask about dust collection. I would like to buy something like this one with little power as my 16A circuit can handle only 3600W in total. DC 200 E - 230 V
Would this be sufficient for bandsaw and jointer/thicknesser? (they will be used one at a time). Are the bags for chips reusable or they should be replaced often?
Thank you.
This machine looks almost identical to the Holzprofi DR250 (which is the little sister of the DR310 model I own). If the build quality is the same then I’m sure you’ll be happy with it.
The dust collector seems like it should be fine for hobby/light use. You might consider adding a cyclone to the set up if space permits.
