Hmm, doesn't buying a Hammer A3 31 be more expensive as you have to deal with the import & if something goes wrong, the company is offshore?
@Oaktree11
Thank you for such a detailed response, it's really helpful to hear other people's experience in this area!
I am leaning towards the AT at the moment despite its disadvantages!
The used one that you found, how did you sort out transport for that?
Good question on leadin times. I waited about 8-10 weeks for mine. But once you've paid and are locked in they hold you in the delivery slot. I wasn't messed around but did have to wait.@Bristol_Rob
Thank you for your time!
What was the lead time in your case? Is there any major part of it that isn't adjustable, such as the table? I think that'd be my main concern
Oh yes, I checked the beds with my Veritas Steel straight edge, I found the in-feed bed had a 0.5mm dip in the middle of the bed. But the rear edge and the edge by the cutter block perfect. So good enough for my needs.@Bristol_Rob
@Bristol_Rob
I recently bought a planer and was considering a spiral head. I was strongly advised by the machinery dealer (JMJ woodworking) to stay away from a spiral head if there was going to be any softwood used on the machine, as all the little cutters and screws will fill up with resin and be a total pig to change.
I just say in fairness to Felder/Hammer they did explain it wasn’t just a case of swapping one tip if one got chipped.He also warned that while the makers promote the idea of only changing one cutter if there is a chip, in reality you have to change several since the new one will be slightly higher than the old ones around it and there will be a groove in the wood as a result.
With regard to noise & I can only comment on the machines I’ve used but can confirm the spiral block is considerably quieter. The best example I can give is with my Wadkin running I couldn’t hear the extractor & would look round to check the shavings were swirling around the extractor bag about 5’ away, with the spiral block I can hear the extractor above the noise of planerHowever if the noise is really important (and genuinely much better with spiral) then perhaps that has to be the overriding consideration for you. I bet they still aren’t quite though!
Really interested to read this Mike & as I’ve run an lot of pine through the planer thicknesser over the last couple of months certainly 10+ large extractor bags worth so as I’m in the workshop I’ve popped the tables up to look & took a photo
