YorkshireMartin":tsx1dnjt said:
wcndave":tsx1dnjt said:
I started doing both cup and bow with the concave side up, and if you make a good deep pass on the first go, it seems to work out much better in the end.
I don't know if this is the "proper" way, however it works for me.
I've never tried that, do you use pressure to flatten the boards on the way across? That would take some serious skill to get right I'd imagine?
Another method I think, is if the stock exceeds the length of the table and is bowed, to place the ends downward and do one end, then flip the board and do the other. Think that is an old school method. (Edit: Exactly what Rodd said basically..)
As Rodd said, it does mean sort of dropping the piece on, and as you get closer to flat, that means it will impact the blade.
Also I think you can approach flat, however you'll always have the end curving away off the end of the outfeed, if it's longer than the planer.
The method I use, I am sure I read somewhere, as I was surprised, it feels more intuitively stable especially with cup, to have the concave side down.
So if I have a board with any cup or bow (so all of them), concave side up, I push down in two places say 1/3 from each end, or 50cm apart max (depending on board length), and run that through on a decent depth (based also on how much width of material is removed, can't do 4mm on a 30cm wide board...unless it's cupped so that I will only take say 5cm width cut)
I typically aim for 3mm. That will in 99% of cases create enough of a flat surface that the next passes can all be done with a nice 1mm odd depth, with pressure on outfeed only, standard technique etc etc....
Whereas if you create the tobboggan rails effect of concave side down, and you got 2 very narrow strips on each side, I would end up with one side narrower than the other, and difficulty getting warp / bow out at the same time as the cupping.
It's not difficult at all unless the board is very badly bent, and say has 1cm deviation, but then I tend to get out a scrub plane and get the worst of it off by hand.
One can end up tilting one way or the other, but it's generally not hard to find the middle balance for one pass.
No idea where I read this, but as it works for me, I'm sticking with it ;-)
OP, when someone mentioned gluelines, I think they meant that there should be no visible gaps in a table top. Of course you will be able to see where the grain does not match up, that's different. PS try to align the grain so you can plane it. If you have boards with grain running in opposite directions, you will get tear out whichever way you plane the top.
I must admit I've been woodworking now many years, and the thought of hand planing a walnut top for a nice table is quite daunting. The first major flat (ish) surface I tried to handplane was my workbench last year, and that was because I knew the WAF didn't give two hoots about it...
Good luck, and post us some WIP pictures!
