El Barto
Matt & Memzy, I think you might be right. Sigh. If I had the space/money/time it could be a nice project. Maybe another time!
El Barto":y0fd1gje said:Still on the hunt for a PT. Would this be a cool project or just a massive waste of time and money? It looks ok except for the motor...
https://rover.ebay.com/rover/0/0/0?mpre ... 2379383800
MikeJhn":4jyrkp4o said:My advice is don't touch it with any pole let alone a barge one, there are so many good PT's out there why go for one that needs that amount of work?
Mike
El Barto":2y9umk6r said:Could be fun :?
MattRoberts":34h1vjb4 said:El Barto":34h1vjb4 said:Could be fun :?
If you already have a P/T, yes. If you want /need one? No
Hi you need to buy the self set blade holder to suit your machine then buy whatever number of blades you require not the cheapest I know but the time it saves on setup makes it well worth while I think of the top of my head cost me about £100 for the blade holder and 3 sets of blades, I used to pay around the £20 mark for the genuine Electra bekum blades which where good blades but did not last that long on hardwoods the new blades seem to hold their edge better, As to fettling the machine I had to raise the outfeed table by about 1.5mm as the esta bruck blades sit slightly higher but this was easily done as the outfeed has grub screws to assist this, the only other thing was the depth gauges when you set both tables to 0 alter the thicknesser gauge and the surface gauge allow for the difference in the blade height this is done by slackening 2 screws on each gauge the move accordingy. Hope that kind of makes sense but it really is not hard to do.galleywood":nl6mmc3n said:Ring
Did you have to purchase any items, apart from the blades on the link you provided.
What fettling was involved.
I have been trying to find my receipt I have a feeling you could be correct so my guess at £100 might have been wrong the best thing to do is fire them an email or give them a call they are spot on to deal with I have no connections with the company just a happy customer hope that helps. I will keep looking for that receipt maybe I was hiding the cost from the wife lol.MattRoberts":3rb2zyj9 said:Thanks for the info Jim. I assume the holder and blades are sold as singles? So a two knife block needs two holders and two blades (about £150 Inc vat)?
El Barto":18oo3mv1 said:Can anyone tell me the difference between the Kity 1647 & 638? There's one of each on eBay from the same seller and fairly local to me but can't find a whole lot of info out there about them. I know that the 1647 has a 3 cutter block and can plane up to 12 inches. Both run off 13amp - bonus!
One day this topic will be long forgotten but it doesn't look like it'll be short of replacements by the look of things...
