Planer thicknesser blades
Johnny65
20 Sep 2020
Lowestoft
Hi all,
My original planer blades are,
210mm x 16.5mm x 1.5mm
Can I use,
210mm x 18mm x 3mm
I can't get the original size quickly so wondered if a slightly bigger size will fit.
It depends, if you can't get the ne blade down further in holder, then the top blade edge will be above your outfield table, so unless you can avoid this then I'd not use them.
