I've read several of the threads here on this and am thinking of getting a planer, and maybe a thicknesser. The first use I'd have for this is to square up and flatten 8ft long, 8" x 4" oak 'sleepers' which are green to semi-green, rough and slightly bent. Obviously, they're a bit heavy..! I can only lift them with one end on the floor, so would have to lift an end onto the machine bed then raise the whole timber - maybe using a roller stand.
I think I've understood that I need to use a planer first to get one true face. If I've understood right, the timber rests on the planer bed and is fed through automatically by the machine with the cutter drum rotating above. Presumably the bed needs to be long enough to 'average out' any banana shape over the length of the timber to get a true flat face..? Would I then use that flat face to get an edge square to it, feeding the timber through stood up? That does sound a bit dodgy to me.. do any of these machines have two cutter drums square to each other... or is that only on industrial size machines?
What would I need for this, and how much will it cost to get something solid and reliable enough which will give a reasonable quality finish? The other issue I have is that the workshop is quite damp at times, so anything cast iron will probably be prone to rust.
I'm not sure I'll need a thicknesser..? I'm cutting the sleepers into two 100mm x 75mm lengths and one approx. 100mm x 40mm using hand-held circular saws, as I don't have a table saw. Other than this I've been buying oak ready sized as I need it for the jobs I'm doing.
