mr":24sax3cw said:A wheel gauge or cutting gauge -ie with blade should be less prone to follow the grain that a marking gauge with pin, or a pin ground to a bevelled edge.
Cheers Mike.
And then there's always a pencil in the end like my panel gaugewoodbloke":2mk3rqi1 said:Mike.....depends what sort of gauges you use :wink: - Rob
engineer one":3n3te2b3 said:must either make or buy some winding sticks. anyone tried the axminster ally ones. are they any good???
Paul Chapman":39qg24ny said:Just get two pieces of wood, say 2"x1"x18", clamp them together on the bench top and plane them up. They don't even have to be perfect, but need to be the same (which is why you should plane them together). In use, keep the orientation the same (so mark them) and off you go :wink:
Paul Kierstead":2wygq6ly said:Paul Chapman":2wygq6ly said:Just get two pieces of wood, say 2"x1"x18", clamp them together on the bench top and plane them up. They don't even have to be perfect, but need to be the same (which is why you should plane them together). In use, keep the orientation the same (so mark them) and off you go :wink:
As a further hint, a dark one and a light one makes it easier to see. If you have two light ones, I hear that marking one of them along the corner with a sharpie achieves the same thing.
