Yes, but where's the fun in that?I just had a response from Ray Isles regarding surface grinding of a #7 sole. £22.50 plus VAT, and shipping each way. So I reckon £33 all told. They'll do the sides too for another £7.50 plus VAT
Yebbut that's cheating!After restoring one too many old planes, I built a belt sander using a platen of (supposedly very flat) tool steel. I consider that to be lapping the easy way![]()
How accurate is that? Reason I ask is that I've tried it with the belt sander at work but it tends to take more off the edges.After restoring one too many old planes, I built a belt sander using a platen of (supposedly very flat) tool steel. I consider that to be lapping the easy way![]()
They're flat enough such that my limited talent with a hand plane doesn't notice any problemsYebbut that's cheating!
Do you get a perfect flat surface such as would satisfy the committed sharpen and polish crew?
I can't remember the exact size of the platen (not at home at the moment to go and measure it) but it'll comfortably take a #4 or #5, with just the larger planes needing to be moved across the platen to surface all the sole.How accurate is that? Reason I ask is that I've tried it with the belt sander at work but it tends to take more off the edges.
I did look at a Paul Sellers video, and he even goes to the trouble of creating this unevenness, so not sure if it's a good or bad thing.
When I was building a lot of planes I had a large industrial belt sander. It had a wide cast iron bed and comfortably handled a jointer plane. The belts were six inches wide. It made lapping soles and, with its fence, squaring up the sides a really pleasure. The planes were all infill with steel sole and sides so quite a bit of work required in the finishing.After restoring one too many old planes, I built a belt sander using a platen of (supposedly very flat) tool steel. I consider that to be lapping the easy way![]()
Agreed. I used Matthias Wandel's belt sander plans (Homemade belt sander) for the rollers, and tensioning and tracking mechanism. If I recall correctly, I may have used a slightly smaller roller diameter in order to extend the distance between the two rollers slightly. I bought a 6mm plate of tool steel, guaranteed flat to <some decent tolerance I can't recall right now> and used that as the platen. The sander itself is actually powered by my lathe, and hooks onto the ways for support.A belt sander with a really flat platen and a lot of belt tension could absolutely do crude but functional flattening of a plane bottom (be sparing if you like the plane, though).
The hard thing for the average person to do is find a belt sander with a flat enough platen and enough belt tension.
