Steve Wardley
Hi Guy's.
I'm aiming this question at those who have in the past repaired or refurbished a hand plane.
I've recently come by a Record No4 smooth plane that needs a little TLC and one I have decided to clean up a small amount of light surface rust and re-varnish the wooden handles.
Now the main rear handle is in two pieces, perhaps due to a loose main screw or the thing having been dropped but the two halves fit together seamlessly and I am wondering if normal PVA glue would be suitable to fix the two halves together prior to varnish and re-assembly or if there is a better alternative.
I will of course be making sure the main top screw is kept tight to avoid this repair being stressed once it is back in service.
I'm not minded to use epoxy as I think it would create a joint too wide to be mechanically sound unless there are opinions in favour of it.
Cheers in advance, Steve
