A
Anonymous
Guest
bugbear":1snt7seb said:In theory at least, there's nothing to even put a secondary bevel on!
In practice there is and it has been working very well for me for a very long time...........
Tony":e7j8gprl said:Here you are bugbear - this one is ground at around 26.5 degrees it turns out (I don't check too carefully, as I don't really care if it is a couple of degrees out on the primary bevel grind)
Tony":1gdhdj0a said:bugbear":1gdhdj0a said:In theory at least, there's nothing to even put a secondary bevel on!
Yep - that's measuring the chord, which (as discussed) is OK as long as the wheel is "reasonably" large.
Wanlock Dod":1frqwgdi said:Yep - that's measuring the chord, which (as discussed) is OK as long as the wheel is "reasonably" large.
So Bugbear, are you going to reveal how big "reasonably large" needs to be before this isn't an issue any more?
Cheers,
Dod
Wanlock Dod":1ki6412m said:Yep - that's measuring the chord, which (as discussed) is OK as long as the wheel is "reasonably" large.
Cheers,
Dod
Harbo":1jzxtijz said:One thing I experienced today (and it was confirmed on Alf's Blog site) was that the bevel angle on Plough Cutters (Record 43's) should be 35 degrees. This in practice equates to the bevel being parallel to the sole and therefore offers maximum support.
I tried out a cutter which had been ground with a 25 degree bevel and a tiny piece of wood became jammed between the iron and the frog - reducing the performance considerably - it was quickly reground to 35!
Harbo":1idmgpqu said:One thing I experienced today (and it was confirmed on Alf's Blog site) was that the bevel angle on Plough Cutters (Record 43's) should be 35 degrees. (snip)
Rod
Harbo":33nosmf6 said:How about a toad? :wink:
Frog or bed - the sloping bit that the iron beds on.
What do you call it?
Rod
