@weigen369 ..that was a "mic drop" of a post ![Love :love: :love:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks PaulScraping
It’s all in the realms of deminishing returns. As with anything there is a “good enough” point that meets 98% of needs. I’ve scraped a couple of planes purely because I could and it was what I was into at the time (making planes). Generally now I just use them as I have a fairly comprehensive set to meet my needs. Frankly unless I was engaging in competitive shavings I wouldn’t be too concerned with the sole provided it appears flat against a straight edge.Thanks Paul
Never had to do it so never considered it .
Just all seems bit excessive to me and I wonder what was done to the sole previously.
I’ve never had a plane from any manufacturer- Record, Stanley, Veritas or Quangsheng that needed so much work.
I could get a board edge flat with a block plane and straight edge if that was all I had.Aet1,
do you have planes with 1.5 thousands tolerance? If don't, then what is it, +/-2, +/- 3 thousands?
That was the original question, how flat (I would also add in what direction) does a plane need to be to be functional?
Is it coupled with technique? What technique?
According to Jacob, you can get a straight edge with whatever you have and you only need good technique. Which sounds like a bogus claim when you can't state whether your plane is flat or not. For all I know his planes are all flat.
I found a Bedrock #6 with better than 1.5 thousands flatness, as found. The plane works very well. Should I attribute the performance of this plane solely to my technique?
Is it a good enough edge for a seamless joint?I could get a board edge flat with a block plane and straight edge if that was all I had.
It’s all to do with knowledge and practice not how many thou your plane’s out by.
Of course, I do this for a living.Is it a good enough edge for a seamless joint?
Flat and straight to the eye is good in some cases, but not all.
According to your point of view, jointer planes are unnecessary.
I could ride a horse to work every day if I chose to, admittedly It would take more time but still get me to my destination.And I go back to the original question, is it necessary to flatten a plane to get, for example, good joints?
Yes, no, it depends?
Whatever the answer is, why?
I don't want to sound disrespectful, but I don't care for "i do this for a living" appeals to authority.
If a block plane and a rule can do the job, why? Is that a recommended method? Do you use that method?
Sandpaper, a block of wood and a rule can probably do the job too. I would not offer that as an alternative.
No but it might help.And I go back to the original question, is it necessary to flatten a plane to get, for example, good joints?
For all the obvious reasonsWhatever the answer is, why?
It's not an appeal to authority. Google "argumentum ad verecundiam".I don't want to sound disrespectful, but I don't care for "i do this for a living" appeals to authority.
If that's all you had that's what you'd use. Not difficult to understand is it?If a block plane and a rule can do the job, why? Is that a recommended method? Do you use that method?
You might if it was the best option, due to lack of alternatives.Sandpaper, a block of wood and a rule can probably do the job too. I would not offer that as an alternative.
That is so 1981! I’ve watched, literally dozens of YouTubers this past weekend and they have overcome all plane problems mainly by ”Astro sharpening”. I did not send in my $1.98 and two box tops to get the special instruction, but I will this week.Back in 1981 planes needed to be flat to British Standard is BS 3623:1981 Specification for Woodworkers’ Metal-Bodied Planes, .0015". I don't understand British Standards but I believe this has now been withdrawn, so maybe they don't need to be anymore.
agree with this, this is all that matters really with planes, it's the skill of the user, also we're not engineers we are woodworkers, it's easy to get carried away.I could get a board edge flat with a block plane and straight edge if that was all I had.
that explains a lot! regards, Ben.Well, what do you know? I am an engineer. Trust me, I do this for a living, I'm not dazzled by accuracy specs.
My father was a cabinet maker, I grew up in his shop. He showed me the value of using the tools you have at hand. Once, while visiting me, he made me a coffee table out of bubinga, with mouldings. He didn't use an electric router or a moulding plane. I don't know how he made them, he probably used the table saw, chisels, and sandpaper. It probably took him a long time, but he enjoyed doing things for me.
If all I had were a block plane and a straight edge, I'd go to IKEA.
