Hello,
I am new here and want to learn more about flattening pine boards. I want to build a guitar and have some scrap pine as practice. I think that when I glued them I might have offset them slightly and it seems that one is slightly higher than the other. I have tried to flatten them on both sides using an electric plane (cheapo from screwfix). It seems that the centre is higher and as I try to plane this, many times with the planer at increasing depths, the centre still seems high. on the other side of the board, i think cupped is the wood, but no individual boards. I did not plane either board before gluing. I am not too sure how to use an electric plane. when I tried to flatten a board first time, I ended up cutting deeper closer to me and gouging the ends.
question 1, Do you put pressure on the plane through out the cut or just hold it on the wood? I heard somewhere that pressure causes gouges, I also have undulations in the woods for some reason.
question 2, Will the silverline be better at removing the problems I am experiencing with the electric plane.
I dont like the electric plane so much as it is really noisy and think that maybe some experience with a hand plane would be better. Sometimes with the electric plane it does not feel like it is planing at all, just going over the wood. I have watched a few videos on electric planing with no luck. I am sure it is a technique thing.
Any advice would be great
All the best
Simon
All the best
Simon
