piggybladder
Hi all, please excuse a silly question. I own a cheap Anant n04 plane, (I'm not mean or trying to be clever making a silk purse out of a sow's ear - just dirt poor!). I lapped the bejaysus out of the sole and have a scary sharp blade so it works fine but I have semi-permanent grazes and callouses on my left thumb knuckle where it consistently hits the lateral adjuster. The problem is I'm cack-handed and the lateral adjuster has to swing a fair bit to the right (somewhere between 1 and 2 o-clock) for the blade to sit straight. This results in it catching the top of my first thumb knuckle. I have a sloppy grip too due to illness, which compounds the problem. I've also noticed that the lateral adjuster on my n06 is also always biased to the right but doesn't cause a problem as the tote is further back from the lever.
I always thought that this problem was simply coz of the crappy machining on the frog/lever, (which is certainly true), but it occurred to me that maybe the lateral adjustment levers on all planes are biased this way to suit right-handed people who form the majority of the market? I should add that I have fairly small hands. So hand size isn't the issue. Anyone got any thoughts on this before I run off and buy a s/h Stanley frog?
