Richard T
I recently cut two pieces of white pine (very similar to Scott's Pine) with my bandsaw. It was four cuts of 6" x 6'9" and by the last cut I noticed I was slowing the motor down -unheard of! On closer examination I saw a build up of resin and sawdust coating the inside of the blade.
It had set like glue. Not only were the teeth partially coated, but the extra surface on the inside of the blade was making it ever tighter on the wheels. Hence slowing the machine down.
Has anyone had the same experience? And is there any way to discourage resinous dust to stick so fast?
It doesn't happen with conifer - the sticky resin seems to be only near the bark with them, whereas pine is sticky all the way through.
In the end it took me longer to clean the bade with a big, flat screwdriver and lots of elbow grease that it took to do all the setting up and cutting.
btw the blade was a DF "ripper" 2tpi and I do have the wheel brush set ok.
