MikeK":203e5le1 said:Maybe the bread is intended to go under a broiler with a bit of grated cheese sprinkled on it.
I make it regularly, I'm baking later - but the boy won't eat any read other than crepe sliced bread with the "crusts" cut off. It's useful once in a while for toast. In fact, that's all it's useful for.Glynne":2p3fj33b said:What happened to the homemade bread?
Steliz":17d7lwqm said:On the subject of toasters - mine has settings that range up to 7 but produces perfect toast on number 3. If I put the setting up to 3.5 then I get black toast so what are the other settings for?
phil.p":3jfssxgs said:Yer but..... no but ....... It doesn't say the slices are two inches higher than a toaster slot.
Sheffield Tony":15mccu8j said:Steliz":15mccu8j said:Why are toasters so c**p ? They rely on a timer or other guestimation method to determine when the toast is done, traditionally a bimetal strip with a heating coil around it that releases a latch when it gets hot enough - so it is affected by the ambient temperature, whether this is the first or second slice, etc etc - but not how brown the bread has turned ! Industrial baking processes can monitor the colour of biscuits in the oven - why can't a toaster toast to the right shade of brown ?
transatlantic":15146yqz said:Sheffield Tony":15146yqz said:Steliz":15146yqz said:Why are toasters so c**p ? They rely on a timer or other guestimation method to determine when the toast is done, traditionally a bimetal strip with a heating coil around it that releases a latch when it gets hot enough - so it is affected by the ambient temperature, whether this is the first or second slice, etc etc - but not how brown the bread has turned ! Industrial baking processes can monitor the colour of biscuits in the oven - why can't a toaster toast to the right shade of brown ?
No no no! .. we don't need to make them complicated! .. more stuff to break.
ColeyS1":2t22bqy1 said:One side is shorter than the other Phil
The slices are too high/wide to fit in width ways.ColeyS1":24vksjou said:One side is shorter than the other Phil
Lol
Sent from my SM-G900F using Tapatalk
Glynne":301j3fp9 said:What happened to the homemade bread?
