custard
Random Orbital Bob":jdz50ocq said:Again...the problem is the time it takes to grind HSS...its just a bellyache because the stone keeps glazing and therefore stops cutting. I'm resolved to try a diamond dresser to reactivate the stone quickly.
Bob, I also use the Tormek with the Blackstone Silicon wheel which I dress with the TT-50 diamond truing tool. Unfortunately, even with these measures, the Tormek just isn't a very quick grinding tool, and if I've got a lot of material to remove I use a Cubic Boron Nitride wheel on a regular grinder. The CBN wheels aren't as cool running as the Tormek, but they're much cooler running than other grindstone wheels. They remove material really quickly and with virtually no sparks which feels strange at first. Another advantage of CBN wheels is that they're bonded to a metal wheel, so once that's trued and balanced there's no need for any subsequent truing.
Going back to your Tormek, truing the wheels is an essential step. I pretty much follow the David Charlesworth method for getting the best from a Tormek, true the wheel with the TT-50 (the grading stone is a very crude alternative and you can't get the surface of the wheel parallel with the Universal Support, besides which it doesn't work with the Blackstone wheel), set the Universal Support a fixed distance above the stone using a spacer which you keep for this one purpose, and after truing the wheel don't alter the settings on the Universal Support. Following this method gives good, predictable results from the Tormek, but it's still pretty S....L....O....W and if you don't want to think in terms of 15 minute or longer grinding sessions for a major re-shape then consider a CBN wheel.
