PaulH
My "workshop" is in the roof space of my garage and consequently has no windows for ventilation - even the "door" is in the floor! I was therefore considering buying an air filter to remove the fine dust that inevitably circulates.
I note Axminster currently have their Perform CCAF model on special offer (25% off). On comparing this with the Jet AFS-500, I see the Perform:
1) has a higher rate of air movement
2) has a higher room volume
3) is rated "Hobby"
But the Jet,
4) is 10Kg lighter
5) is significantly smaller in length
6) is rated "Trade"
Both are dual stage filtering and filter to 5 and 1 micron at the first and second stage respectively.
I'm assuming that the higher rate of air movement would be "better", so why is the perform only rated "hobby" but the Jet rated "Trade"?
The lighter/smaller system would be "preferable", but given the extra "volume" and higher rate of air movement, I guess the Perform is "better" and therefore currently a "good deal"?
Is my analysis correct and does anyone have any experience of the Perform filter?
Thanks,
Paul.
3) is rated "Hobby"
But the Jet,
4) is 10Kg lighter
6) is rated "Trade"
Thanks,
Paul.
