The unhelpful answer is neither... they are just not compatible with each other.
The more helpful Tom is to ask what is the diameter of the mandrel, and does a 7mm OD tube fit on it.?
I found when I made mine that although most references refer to the madrel being 1/4" (.250"), if they give any dimensions at all, I found that the mandrel needs to be more like .246-7" diameter to guarantee that most kits fit, and the few thou. slop does not appear to give any problems with the thinner walled tubes.
One of the main problems with all things lathe/tool related is the glib use of imperial and metric equivalents by the vendors when they are totally inaugurate in relation to mating fits.
