I decided to make my own pc desk with the pc built inside it for as little money as possible.
i used 2 sheets of 19mm mdf an offcut of 6mm and 2 lengths of 3x2" timber.
i also bought some steel to make a triple monitor mount
heres the monitor bracket assembly
the monitor bracket is spot on and theres nothing id alter about it if i did another. its also VERY strong partly because i fastened a batton to the wall behind the top rail so the whole thing is bolted to the wall not just the desk.
You could easily hang 40kg+ off it so the 7kg ish monitors are no problem.
For the desk itself i started with a rough layout of the pc parts (i pulled a scrap pc case apart for the drive mounts and mobo plate)
i knocked up a quick drawing too (which altered every 5 minutes lol)
i made a baseplate with an offcut and but spacer rails on the bottom for cable management
(if i do another desk il make this space underneath bigger)
initial work
main desk nearly done (iv since made a circle cutting jig for the router which il use for the 200mm fan holes)
the section at the back is for all the cables going to and from the pc
this is the control console (its since changed a bit)
hole cut and routed for a glass plate to sit in and cable access door fitted
both desks built and offered together and they fit perfectly
centre monitor mounted plate made (complicated pipper because of the monitor bracket layout)
plate mounted onto the bracket
desks fitted in situ and pc gubbins going in (the green stuff is water for the water cooling loop)
pc itself nearly complete (the strip around the top is a uv light)
this is the view through the glass plate at night (thanks to uv light and uv reactive water)
nearly there
hmmm what to do with a spare subwoofer and car amplifier
why not wire it into the 12v rail on the psu (via a switch in the console so i can turn the sub off)
ps yes i tidied the cables up lol
mk1 console (top button is for the sub + sub power light, middle is power + power light and the bottom is the reset button + hd activity light, the black thing between the top 2 buttons is a microphone)
the mk1 was a bit naff so i found a better bracket and rebuilt it
heres the mk2
all loaded up
the 2 holes in front of the keyboard are so i can bolt my steering wheel to the desk when i want it
overall im chuffed to bits with it, theres a few things id do differently and id like to use some proper wood instead of painting mdf! but the actual quality of it is very good, everything lines up/fits perfectly nothing moves or wobbles etc and the pc itself runs very very cool and is almost totally silent (thanks to the water loop + large case volume & large fans running at low speed)
iv got PLENTY to learn but im happy with my 1st real attempt at building something
initial work
nearly there
heres the mk2
all loaded up
