Jacob
What goes around comes around.
You start to appreciate how well a dehumidifier works when it stops.
This is the water collecting channel as fixed to all the single glazed windows in our chapel conversion (still work in progress).
The pipe got blocked and this one filled up with water running out all over the place. There was a lot of it!
I've cleaned it up and it now drains well but not quite enough fall on it to clear completely - needs a bit more fettling, which I'll leave until next summer when it's dry.
The point is - it's amazingly effective and lots of water gets taken out, as soon as the temp falls enough. This means zero condensation on anything in the room as all will be warmer than the window glass.
One day I might attach a bottle to the outside to measure it.
