And on my Epson scanner printer (A3 size that takes BIG cartridges and only cost £100 at Currys) this ink overspill thing is now a box that can be replaced by the consumer just like the cartridges.
On my epson a few years ago I fitted an overflow tank and rerouted the overflow tube away from the "pad" into it.Don't single out Epson! ALL ink jet printers have the same overspil collectors. As it happens, Epson have extremely fine contol on the amount of ink being released since they 'Pump' the ink whereas all other manufacturers use the 'Bubble' principle which gives little or no control of the ink dispensed so therefore have a much greater 'Excess' that must be soaked up.
Get a cheap Samsung laser printer. Probably £40-60. Replacement aftermarket cartridges are about £10 and the ink doesn't dry out. Good for 1000 pages per cartridge.we just binned our Cannon scanner/printer...the ink dried out again.....
pratted around on and off for too many hours trying to fix it.....
we now get the local copy printer place to do it.....
about 5P per double sided copy.....
they will even print the next size up from print paper.....about 50p per sheet.....
so why bother.....!!!!!
I replaced the print head on my Pixma MG7550 last year, about £45, plenty of YouTube vids on how to do itI have an old Cannon Pixma photo printer that served me well for about 10 years.
The print head gave up the ghost, so I'm currently considering whether to get an original or an aftermarket one,
or just buy a new printer.
10 years is not a bad innings for such things, though.
If things don't work out I'll give them a shout. Corsham isn't that far awayI used a company called Fotospeed in Corsham (Wilts) fro my paper supplies and ink jet system of refillable cartridges.
I believe it's more of a print 'counter' thing. Epson probably work on the idea that the printer is in use regularly so changing cartridges & purge of the ink heads will fill the ink pads tray by X number of print jobs.This sounds like an elapsed time thing, because I doubt Epson installed a sensor in the ink pads to determine how full they are!
Even if they start leaking, deffo DIY repair, especially as Droogs has the manual. I've fixed my Canon several times.
Beware if you're just going to carry out some sort of software reset - I reset an Epson printer a few years ago that was giving a similar message and carried on using the printer for a while, until I noticed one day that there was a growing puddle of ink on the desktop under the printer! Yes, the catch pad/tank had overflowed and there was only one place for it to go!
G.
Appreciate the information and the link but I came across that page while searching. The program wouldn't download from them though.The reset software for Epsom printers is called SSC Service Utility. IIRC it's author is Russian but the programme has been in common use for years. Lots of info & available to download from
- Epson printer resetting software and maintenance ( The INK Store )
You can download the resetting tool for that message. the message is more time based than actual state of the ink pad. My Epsom was in service daily in the computer shop for over 12 years and was reset several times with the re setter. I have it somewhere if you can’t find it. Pm me if you need it.
A very common fault for Epson printers from my days at repairing them. There is a pad that sits under the printhead rest postion. You can take it out and clean it with IPA let it dry an put it back but you do have to nearly totally dismantle the printer to do so.
