Wilson joinery
Hi all, I’m currently making an mft table top for my track saw using the parf guide system. Problem is the instructions say not to have anything underneath the table top when cutting the 20mm holes with the forstner type cutter. This is resulting in breakout on the underside of the mft top. My first question is, does this matter? (I was hoping to use the second side of the top once the first is worn out). Secondly how do you resolve this? Do you ignore the instructions and place a bit of scrap under each 20mm hole you’re going to drill or is it possible to drill roughly halfway through and then continue the cut from the opposite side?
Any help much appreciated!
