Pete Martin has pointed me towards this site, an I'm delighted that so many people liked the panel frame that Brian Evans and I made. Incidentally the original idea came from and old Fine Woodworking.
I'm starting to use blackboard more an more because of the weight issue, but whatever you use, you may find a sheet hook a valuable addition to your workshop.
Take a piece of 6mm MDF about 300mm wide. The length is determined by your height. With you arm and fingers pointing dtraight down, measure the distance from the ground to your fingertips. This is the length.
Rout a handhold and line it with a piece of split hose pipe for comfort.
Glue a piece if 25mm square stock along the bottom edge then another piece of 6mm MDF, to form a lip.
You should now have a board which hangs just a couple of inches off the floor.
Hooked under a sheet of MDF, it makes carrying it much easier than trying to hold it by the edges. It doesn't make it lighter though :!:
Look, so easy a girl can do it
For more of my stuff please visit
www.stevemaskery.co.uk
Steve
