I have begun renovating many sash windows in a Victorian.
Existing paint and glazing has been removed, repairs are ongoing however I am a carpenter with little knowledge of paint and generally clueless on what finishing to use, either type or application/coats.
I've heard others argue both for and against the use of water based paints externally, a number swear only to use oil based.
The existing window joinery is largely (I believe) pine with a number of oak cills. Sash and box frame repairs will be made in accoya, cill repairs in sapele with Repaircare epoxy used where necessary.
I plan on using Repair Care Dry Seal MP, to putty in the glazing and I believe to will accept a range of paint finishes.
Given the time of year, a paint that offers quick drying time between coats would be favourable.
Also as I plan on delving into the world of spraying finishes on the interior carpentry I install, sprayed finishes are up for consideration.
I'm unsure which, if any, type of paint may tick those boxes so would really appreciate any opinions offered.
TIA
TIA
