Pads for sash clamps
Search for Paul Seller's website and his video of adding rigidity and pads to those types of clamps.
... and his great tip for filing the corners off the hole to make it slide easier. I'll be doing that with mine tomorrow.
I prefer something like this
Item no 330967517128 on eBay. Self adhesive silicone rubber sheet 1.5mm thick
All those pads look too soft, in my view. Even ply. I use an off cut to spread the load over at least 3 or 4 times the area of the clamping faces.
Rather than where to get pads, I'm much more interested in where to buy spare pins. Three or 4 of mine (the old-fashioned T bar type) are without pins, and it doesn't look too professional to have screwdrivers sticking through them on a big glue-up!!
Mine all have 6mm ply superglued to them, cheap and easy to replace if i need to. I did have leather on them but found it bade a mess if I got glue on them. I also wax the bars quite regularly as it stops any glue sticking and makes everything move a bit easier.
Matt
Cotter pins? :)
when I rip the edge of a sheet of MDF the 1" or so that's left gets cut in to small 1" square blocks, these get used for all sort of stuff from clamping cawls to jack blocks when painting. if they get a bit messy they get chucked. (I also have a tub of sticks from off cuts that get used for thin clamping cawls and paint/glue stir sticks)
I remember reading something by Peter Kay where he gave numerous ways of knowing you were getting old - one of which was putting away long, thin pieces of wood to stir paint. I read this less than five minutes after I had put away long, thin pieces of wood to stir paint. :D
