Chris_belgium
- Joined
- 7 May 2006
- Messages
- 272
- Reaction score
- 0
Recently renovated my rain gutters using padouk cladding and had some serious offcuts, perfect for some training with the stots dovetail template I recently bought.
Imagine doing this in the UK, the HSE would give you a life sentece :twisted:
About the stots template, very simple thing, you use the plastic template you recieve to make a MDF working template. Wich looks like this:
The idea behind this is, if you route into the working template it's not that bad, you can make as many as you want with the plastic template. Another advantage is, you can make you working template as wide as you want and also make templates with different tails/pins width.
First ever dovetails I've machined, the jig is setup so it leave the pins/tails proud, so this is normal, a quick pass with the sander and their flush.
For the test piece I used aphselia, for the box on the other hand I used the padouk offcuts from the rain gutter cladding. This is a very beatifull wood IMO but a real `$$$$$ to work, it's very very splintery, and the grain direction changes, so it's hard to plane.
First piece was a disaster
Putting the router on maximum speed, and very very carefull routing resulted in this.
As you can see still some break out, but a lot less than the first piece.
All in all a very cheap dovetail system, I've built my working template out of mdf and just screwed everything together, I should've built it out of multiplex and used a comination of glue and screws to keep everything alligned and square.
It takes about an hour to build both the tails and pins working template. Once it's set up, it goes quite quickly, took me about 30mins to route all the dovetails for this box. Don't know how fast the leigh jig and consorts are, but this is plenty quick for me!
Box is an exact copy of someone elses design, found the picture on this site, but cannot remember the original builder, but if he reads this, thanks!
